Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
Rear pinion seal change help
Old 11-22-2007 | 11:09 AM
adown's Avatar
Default Rear pinion seal change help
Hi Guy's, I need to change the rear end pinion seal on the wifes 03 excursion diesel4x4. Is this a simple unbolt the flange replace the seal from the outside procedure. Or is there a crush sleve I have to be worried about over crushing and changing the pinion to ring gear clearance. Thanks, adown
Old 12-06-2007 | 12:20 AM
Jawsgear's Avatar
FormerVendor
Response may be late but there is a crush sleeve and preload must e set.
Old 12-09-2007 | 12:56 AM
SVT_Scott's Avatar
easy fix any reputable shop could do.
5.3Caprice
11-07-2015 09:56 PM
thunder550
10-08-2015 05:53 PM
DarkhorSe_SS
08-20-2015 09:58 AM
Dezert1500
07-30-2015 03:51 PM
