224/114 Cam Dyno results
Cant say i'm really happy. I was hoping for a small improvement at 3500 up but actually lost Torque across the chart and lost Hp until 4800rps where it takes off.
Where my previous TQ was 329.4@4500rpm it is now 327.3@4874rpm
" " " HP was 304.3@5263rpm it is now 339.3@6500rpm.
Cam spec is 224/224 114 lsa .578".
Was i expecting too much?
EDit: Dyno chart.
EDit: Dyno chart.
17,16,15,14,13,12,11 Drvr
well you gained 35 more hp thats a plus, tq was lost due to the 114 LSA, it also could be a difference in a spike, you have both graphs? take a look and see where you lost it, could be heat soak, could be alot of things.
Post the graphs up so we can cross referance.
I'll really interested in what you have going on because your numbers seem high stock and even high now with the cam.
Dyno charts
What will happen if i have the cam advanced 4degrees.? Would that keep the curves the same but put the peaks back a few hundred rpm ?
Or does advancing the cam alter the curves also?
Thanks guys
Edit: Shifting at 6250? Tach only goes to 6000 but i think thats where Rick has it. And yes the stall is in and is good. A little weird, but i'm sure i'll get used to it quickly .
According to the graph your HP looks about right. You say it peaks at 6500 but it gets right about the peak just prior to 6k which is normal.
The only part I'm concerned with is the lose of TQ. Anything prior to 3k isnt such a big deal with your converter but you are losing a decent chunk in the lower region.
