300hp RWHP "SAE"
#21
Dynojet inflated numbers? I knoiw my Dynojet shop has a loaded setup using a brake of sorts. Maybe some Dynojet models are unloaded and not all?
I know some NASCAR teams in the Atlanta area use this same shop. I thaught Mustang dynos were the one that read more then the standard. Only by what I read here and there anyway. I'm no dynomometer expert.
#22
#26
i have seen a dyno run that said a 5.90 car only made 300hp to the rear
i was hoping for a 5.90 in my daily "truck" too LOLOLOL
#27
Where's the Beef?
A mustang dyno has a certain amount of resistance that simulates real time driving by not making the rollers easy as easy to spin, Because of this, A mustang dyno usually shows lower numbers than Dynojet.
And yes, all manufacturer hp/tq ratings are at the flywheel.
#28
The dyno jet with simulated brake is meant to apply a brake to the dyno so that it creates a load on your engine. Otherwise it's like jacking your truck off the ground and seeing how you without a load.
