Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
390 rwtq from almost stock 5.3
Old 01-03-2011, 03:10 AM
  #31
GFYS and STFU
Spoolin's Avatar
Something's wrong with your 408!!
Old 01-03-2011, 03:31 AM
  #32
Bumpers's Avatar
Originally Posted by SRTKLLR
Probably a little wheel spin on the rollers. The 322/338 seams to be more correct. My 408 with 224/231 .595/.595 and AFR 225's only put down about 300/320.
I would be pissed
Old 01-03-2011, 03:37 AM
  #33
SRTKLLR's Avatar
Originally Posted by Bumpers
I would be pissed
I managed a 8.2 at Irwindale and 13.3 at Fontana in the heat. It is like people say Dynos don't mean anything they are just a tuning tool and to see if the mods you installed helped. The real measure is the track.
Also, the 408 was built with boost in mind so it has a 9:1 cr and I am running stock exhaust manifolds and stock intake/box. The numbers were from a load bearing dyno(Mustang and DynoDynamics) not a DynoJet.
Old 01-03-2011, 08:53 AM
  #34
quicksilverado's Avatar
If there were wheel spin, there would be a dip in the graph instead of a spike.
Old 01-12-2011, 01:26 PM
  #35
L$X$10's Avatar
im running almost the exact same setup...here's a graph of my pull to compare to:
ps: its STD
Old 02-08-2011, 01:07 AM
  #36
In-Zane Moderator
ZONES89RS's Avatar
Youre right I didnt look at the scales close enough on the side. So by this graph it looks like his true numbers are ~322/338.
Well, that is not bad for a 5.3, maybe i will dyno my 5.3 when it is done, i am shooting for 350 RWHP or so, not that it will reflect what the track times look like, but in a 86 TA with a stall and a larger cam, it will be fun. I really want to know what the little 325 is capable of with cam only, but i am cheating, using a carb. Unfortunately the shorty headers i will be using will hold back a bit, but i am chopping the collectors off for 3 inch pieces to do what i can to retain the ability to get the exhaust out as much as possible.
Old 02-08-2011, 01:38 AM
  #37
9 Second Truck Club
stock48's Avatar
I agree! The Dynodynamics dyno In colorado springs is way down on power from the other dynos in town. The only real gauge of HP is the mph at the track, but that's hard too when you are talking trucks, vs cars, 2wd vs awd/4wd etc.
5.3Okasai
03-09-2022 01:07 PM
OLD BULL
08-01-2015 05:00 PM
steves86ta
07-28-2015 10:21 AM
Choda
07-21-2015 03:47 PM
bk_cauley
07-19-2015 09:56 PM
Quick Reply: 390 rwtq from almost stock 5.3
