5.3 Silverado 08
its a dynomite dynometer, but it was calibrated to read the horspower exactly like dynojet
my next mod would be the CAM, i searched the forum and went clueless i dnt know what to choose now. Comp Cams would be the cam i would go for i want something that would help the bottom end without sacrificing the top end. what do u think of this one http://www.jegs.com/i/Comp%20Cams/24...51-11/10002/-1
http://speed-eng.com/store/comp-cam2...63-p-1494.html
http://speed-eng.com/store/comp-cam2...32-p-1495.html
http://speed-eng.com/store/comp-cam2...34-p-1496.html
that is a baby cam..u wont like that to much. These 3 cams are pretty popular here on pt..
by the way do u know what is the factory profile and lobe separation of the CAM.
i will be running the stock torque converter, so will i be ok if i used one of the top u mentioned, the lift also high so my concern is with the stall i have i may loose the lunch " bottom end"
12 Second Club
on the older iron block 5.3L that was rated in the 285-295 range the stock specs are 190/191@.050 with .466/.457" lift. I'm not sure what the lobe seperation angle was though. Somewhere around 114-116 would seem right.
Where's the Beef?
I'm running the middle cam of those links and haven't lost a lot of bottom end. It's a real good cam. Besides, if you want to get it back just put some gears in. Doesn't hurt your mpg as much as you think.
Dyno jets read higher numbers so you can still squeeze out plenty more rwhp. The dyno i was on reads real low.
