Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
5.3L with HotCam
Old 02-24-2007 | 11:48 PM
YenkoST's Avatar
Default 5.3L with HotCam
GM Performance Parts has a package now that has the 295 hp 5.3L with a Hot Cam making 332hp @5500 and 352 ft lbs at 4600 rpms untuned and on 87 octane and still on the stock 9.5:1 compression at the flywheel. It makes 300 ft lbs or more from 2000 to 5750 rpms. Just thought some people would like to know this.
Old 02-25-2007 | 09:04 AM
Tahoe6.0's Avatar
Good info, keep up the good work!
Old 02-25-2007 | 09:12 AM
nightrunner's Avatar
Mr. Obvious
does the power start to taper off or drop off at 4600rpm or is there another reason the arent taking it higher
Old 02-25-2007 | 01:31 PM
YenkoST's Avatar
HP stays flat from 5300 to about 6000 for the most part. The numbers I listed where peak but they took it to 6000 rpms.
Old 02-25-2007 | 03:29 PM
Mr. Obvious
sounds like a candidate for a ls6 intake....
Old 02-25-2007 | 04:02 PM
tdrumm's Avatar
Is this a carbed engine like their 440hp 6.0 crate engine?
Old 02-25-2007 | 06:39 PM
YenkoST's Avatar
Nope, fuel injected.
Old 02-26-2007 | 01:14 PM
zippy's Avatar
I read the cam specs, it didn't look like a hot cam to me. I believe it was the hotter 5.3L cam (L33) and just poorly advertised. Page 70 in the new book
Cam:
.467" I
.479" E
196º I
201º E
Old 02-26-2007 | 03:11 PM
YenkoST's Avatar
Yea I read that but figured it was the stock specs b/c it list the HotCam part number on there but who knows.
Old 05-15-2007 | 07:37 PM
ricoc's Avatar
Do you have a link to this?
