Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
5.3l makes 386 to the tires.
Old 06-28-2010 | 04:59 PM
hellbents10's Avatar
LS1Tech Sponsor
Default 5.3l makes 386 to the tires.
PBMax's 5.3l is pretty much done now.
Its in a ext cab s10.
2007 5.3l I think?
799 heads ported, valve job and a little milling.
BEi Custom 227 cam
dual springs and what not.
Stock intake and throttle body for now.
Custom made headers, 1 3/4 to 1 7/8 with 3" collector.
The spike is the converter lock up and peak power was at 6050rpm.
Old 06-28-2010 | 05:01 PM
dlt76028's Avatar
nice.
Old 06-28-2010 | 05:43 PM
TXsilverado's Avatar
whats up with the huge spike? did it make this kind of power on more than 1 dyno run? the only reason i ask is because after the spike, it doesnt settle back into the old power curve.
Old 06-28-2010 | 06:16 PM
Pray's Avatar
The numbers are higher after the spike due to the converter locking. Lock it earlier and the curve would have been higher. Don't lock it at all and the curve would have been lower. What was rpm at the peaks? I am wondering where the stock truck manifold runs out of steam. Assuming you are running the truck manifold. What was the final compression?
Old 06-28-2010 | 08:07 PM
TIM Z's Avatar
11 sec. Truck Mod
Damn thats a good running 5.3
Almost 400 rwhp ?? Damn i bet that truck can drift!
Who tuned it?
Old 06-28-2010 | 08:22 PM
jophuss36's Avatar
Nice ! Those are some good numbers!!
Old 06-29-2010 | 08:10 AM
LS1Tech Sponsor
The jump is indeed from the converter locking up. We started at 365 for the baseline and kept getting power from the tune from there. It ended up liking 29* and a 12.9:1 afr. Last 3 runs were within a 2hp, peak hp was at 6050rpm.
We just could not get the verter to lock up when we wanted, seems HPT is very buggy on this ECU. The VCM controls would not work well either.
We will work with it more and use it as a intake manifold test vehicle. Going to try a 102 FAST and then a Edelbrock Pro Flo.
Old 06-29-2010 | 01:18 PM
bluecajun5.3's Avatar
11 Second Truck Club
very nice results and combo!
Old 06-29-2010 | 08:47 PM
definetly got that 5.3 running nice.
Old 06-29-2010 | 11:05 PM
fastrt's Avatar
great numbers!! fo sho
