6.0 cam hp too low??
Ok we so took my friends truck to do a dyno tune on the new setup, here are the mods
2004 silverado ecsb 4x4
6.0 lq4 engine
232/234 .598 112 cam
pacesetter LT's with ORY pipe
Performabuilt level 3 tranny
3800 billet stall
The best we got out of it tuned was 311 rwhp and 329 torque in third gear with converter locked. Do these numbers look a little too low for the mods it has?
6.0 lq4 engine
3800 billet stall
First pull made 305 hp then he got the AFR to like 12.7 and with 27-28 of timing. then it made the 311. anymore timing over that would make it loose power. He said that maybe a cable/spark plug could of not been working and make it run on 7 cylinders. thats the next thing were going to check. Also hes running 08 NNBS spark plug wires with tr-6 if that has anything to do with it?
Do remember that you have an NV3500 and do not spin thru a transfer case. Traditionally, the difference between a T56 and a 4l60e on the dyno in an f-car is roughly 20rwhp. So take that into account.
If the truck was running on 7 cylinders, I really think you'd notice it?? After a header install, I forgot to fully install one of the plugs on the coil and it was running on 7 cylinders and it was stumbling and bumbling. Maybe if it was like that for a while though the computer would adapt and it would run smooth. I don't know.
similar mods, similar dyno number but mines a 5.3.... it does look too low, u should be at least 20hp/20tq higher then what I'm at...
