Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
6.0, sts dyno
Old 11-29-2006, 10:41 PM
adam1803's Avatar
Default 6.0, sts dyno
I got the truck tuned today, had some valve float above 5300 rpm so the numbers will definetly get higher when i change out the LS6 springs for something stiffer. Also the trans was slipping a bit so its only on 5 psi right now. So at 5300 and 5 psi it put down 385hp and 427tq.
Old 11-29-2006, 11:07 PM
TURBO8's Avatar
lq4 or lq9
Old 11-29-2006, 11:40 PM
adam1803's Avatar
its an lq4
Old 11-30-2006, 08:09 AM
quicksilverado's Avatar
The 4l80e was slipping?
Old 11-30-2006, 09:08 AM
adam1803's Avatar
Yep, i thought it a bit odd too. I've got an hd-2 kit going into it.
Old 12-04-2006, 08:13 PM
slowec's Avatar
Holy chit!!! based off your #'s I am in the 400/450 range. CONGRATES How does it feel? how are you telling you have valve float?
How much timing are you running at wot?
Old 12-04-2006, 09:26 PM
adam1803's Avatar
It feels really strong, the i know the HP is a little low right now but the torque is still really nice and really gets it moving like crazy. The valve float you can see on the dyno and you can also hear it. I've got 918's and a shift kit sitting on the counter and hopefully i'll get it back on the dyno sometime in January for better numbers.
Old 12-05-2006, 04:50 PM
8ALTNG's Avatar
nice start. What size turbo is it??? I would suggest haveing new bands and clutches put in to the 80e before you make any real power. Turbos love to eat up trannys. Good Luck
Old 12-05-2006, 06:06 PM
adam1803's Avatar
its a 60-1 and the tranny is brand spankin' new so i think a shift kit will fix it up. Im not completely sure that it was tranny slip we were feeling on the dyno because i don't feel it on the street but the kit won't hurt to have.
Old 12-06-2006, 08:32 AM
slowec's Avatar
all I can say is wow. Those are good # for a smaller turbo "like I have". Are you running fans, cam, or any other mods? congradulations! happy you didn't sell it!?
Quick Reply: 6.0, sts dyno
