Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Built/Whippled 03 Lightning dyno results
Old 07-12-2010, 05:54 AM
chrisheltra's Avatar
Default Built/Whippled 03 Lightning dyno results
Major mods:
Forged internals
Heads
Cams
Whipple
Converter
Shop Conditions:
90-100*
90%+ Humidity (It actually rained a few times while we were there)
12* timing
~16#'s of boost (verified by Randy)
Pump gas
Meth line blew during one of the pulls so the power was probably down a bit.
Heres the results
YouTube- Built & Whippled Ford Lightning dyno pull 1
YouTube- Built & Whippled Ford Lightning dyno pull 2
Some new vids from a friends camera
YouTube- Built & Whippled Ford Lightning dyno run 3
YouTube- Built & Whippled Ford Lightning dyno run 4
Old 07-12-2010, 05:58 AM
11 sec. Truck Mod
TIM Z's Avatar
Congrats, Thats a powerful truck.
Old 07-12-2010, 08:40 AM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
What size whipple?? Great number BTW.
Old 07-12-2010, 08:47 AM
2.3L Thanks
Old 07-12-2010, 09:57 AM
Low_LSX's Avatar
Love the color, have been working on some lightnings, and GT500s lately. Why did you go with the smaller whipple if I may ask, and what size pulley are you running? Since your block is built, why not go with the 3.4? You should run a small shot that and will get your numbers up there.
Old 07-12-2010, 10:04 AM
Nobody has proven the 3.4's to out perform the 2.3's without A LOT of added investment in the fuel system and intake system. Dollar for dollar you will go faster on a 2.3 than you will on a 3.4 with the L motor. 2.3's have gotten L's into the 9's 3.4's have gotten L's into the 8's but that was a tube chassis light weight truck with a high dollar motor. Im currently running a 8# lower and a stock 3.375 upper.
Old 07-12-2010, 10:11 AM
Low_LSX's Avatar
I see what your saying, still doing its job and congrats on the numbers will run a lot better with some cooler weather and getting the Meth issue solved. But I still think you should run a small shot to get those numbers higher whenever you can. Badass L for sure.
Old 07-12-2010, 10:29 AM
I should be between 630-650 on my race setup. If I find thats not enough to get the job done I have some wiggle room in my setup to add a 75-125 shot.
Old 07-12-2010, 10:37 AM
Sc00by's Avatar
Nice truck! Love that color!
Old 07-12-2010, 01:30 PM
I bet that thing is a blast to drive. Nice number btw.
Quick Reply: Built/Whippled 03 Lightning dyno results
