Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Cam 5.3 making over 350hp
Old 11-09-2011 | 06:28 PM
400hp ss's Avatar
Originally Posted by dirt track racer 81
Stock torque converter will show higher numbers than a higher stalled torque converter...
Well you loose that power with a stall, where as a stock one doesnt flash as much and loose power
Old 11-09-2011 | 08:23 PM
La RPM's Avatar
Stall converters do not loose power.. I think you should go read up a bit on what stall converters do.. if anything they multiply torque at the line,roll, etc.
Old 11-09-2011 | 08:30 PM
smokeshow's Avatar
Mod with training wheels
Less wheel RPM = less wheel horsepower.
Old 11-09-2011 | 08:33 PM
A Low Dime's Avatar
13 Second Truck Club
How would a stall loose power over a stall if they are both locked in gear?
Old 11-09-2011 | 10:47 PM
364HC's Avatar
Banned
have heard same thing about converters on dynos: hp miscalculations...
Old 11-09-2011 | 11:04 PM
Chevy_King1500's Avatar
dyno is only a tool... wheres the track times??
Old 11-09-2011 | 11:15 PM
grey matter 04's Avatar
i guess you call it convertor slip.
A stock stall will not slip as much yeilding higher numbers.
Say a 9.5 3600 stall will slip more and be looser causing slightly lower numbers
Also a stock stall will have more mph or topend VS a loose aftermarket.
Locked up i think they would dyno the same because its locked no slip unless clutch diameter plays a roll..i think a stock 12 inch stall will have a bigger clutch area vs a 9.5 aftermarket stall
Old 11-10-2011 | 11:36 AM
400hp ss's Avatar
Thank you,
Didnt mean you will loose power it will so less but when it flashes it will show more tq.
No track times tracks closed for winter here already!
Old 11-10-2011 | 12:34 PM
Team Paulie's Avatar
Registered User
Whats this thing sound like?
Old 11-10-2011 | 01:12 PM
05gmcsierra's Avatar
Kinda have to dissagree here.. my ss3600 trapped higher then my 278mm circle d.by 1mph
