DBrods dyno #s and graphs. 7xx
Well I decided to put the truck on the rollers again before I start the stroker build again. This is on a 200 shot with 15* total timing. Still on a stock 6.0 shortblock with ported 243 heads and FAST 92 intake. The A/F on the motor is 12.2-12.4 and on the spray is 11.8 holding steady. The shot is still a little fat due to the higher power numbers. Keeping it safe. I didn't get a print out of the NA pull but it was 580ftlbs and 470hp. Enjoy and all comments are welcome.
Keep in mind this is through a 3200 stall and a 80E with a two piece driveshaft and 4.10 gears.
![](http://i282.photobucket.com/albums/kk272/dbrods/01b2c628.jpg)
![](http://i282.photobucket.com/albums/kk272/dbrods/d5478951.jpg)
![](http://i282.photobucket.com/albums/kk272/dbrods/59fb81d6.jpg)
![](http://i282.photobucket.com/albums/kk272/dbrods/REDSLED.jpg)
I'm still puzzled too on the Torque but thats two different dynos that its read almost the same on. The first dyno a few months ago was 622lbs and 525hp and now this one was 585lbs and 470hp. This dyno pull on motor had 6* of timing pulled in the midrange and 3* pulled from the upper rpms. Compression on the motor is 12.05:1 and the cam is a 232/242 615/609 114+4.
I was hoping for 8xx but that didn't happen. I'm excited about the .5 G's of acceleration. Just goes to show how hard this fat pig pulls..
