Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
DBrods dyno #s and graphs. 7xx
Old 09-09-2010, 07:12 PM
  #41
skeet's Avatar
Originally Posted by twolow02fransen
12 to 1 compression IMO theres no one that i can think of running that much even skeets truck dont make as much as this thing and he has Ls3 heads with the fast LSr.
i ran like 12:5:1 back in the day with 706 casting heads ported, but it wasnt enough for what i wanted
everyone says 12:1 is to much, appearantly they never ran it before, i used to drive mine 70 miles one way to work without any issues...
i will be running the better part of 12 on the 408 gunning for 600 to the wheels
Old 09-09-2010, 08:39 PM
  #42
DBRODS's Avatar
Your not the only one shooting for 6xx to the wheels with a 408...LOL.. My 12:1 was fine also till about 3-4 weeks ago on 93 octane. Then I guess the fuel around here changed, cause it didnt like it anymore.
Old 09-09-2010, 09:08 PM
  #43
skeet's Avatar
i know i know i know lol you'll beat me to it, im in no rush but we'll both be there
Old 09-10-2010, 12:16 PM
  #44
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
no **** thats crazy you must have to retard the timing a bit i would think with that much comp on pump gas or else it would just ping it self to death .
Old 09-10-2010, 12:19 PM
  #45
LIL SS's Avatar
Originally Posted by SincalT/A
I really hope it works out for you in the long run...One things for sure the lean spike is not gonna get any better when you squeeze off a nice full bottle at 1100psi.You hot lap on that bottle make sure theres a broom,dust pan,and cell phone on board.
Why are running bottle pressure at 1100psi? How much pressure drop do you have at the end of a pass with say half a bottle. Going rich? Jet it for 900psi and I bet it doesn't drop near as much, and it should be more consistant run to run.
I'd be running 12-1 or more with my new 418, but I didn't feel like milling the brand new AFR 225 heads I had. But I see no problem with it is it's set up with the right cam and tune. But what do I know..
BTW, some of the reason he has more TQ than your example? My guess, the cyl heads and compression have a lot to do with it. That LS3 head is what a 260+ cc runner? Probably a lot bigger than DBRODS's.. Port velocity suffers, and when that happens, so does TQ.
I will be running the better part of 12 on the 408 gunning for 600 to the wheels
I wish you luck on the 600rwhp 408. I'm hoping my AFR headed 418 makes 530ish through the 80E and 4,56 gears 12 bolt, with 11.15-1cr 245/260 .64x/.62x cam.. But I should be able to make up for it with the 2 stage N20 kit
Old 09-10-2010, 02:15 PM
  #46
skeet's Avatar
i'll be realistic here, if i even come close to 600 to the wheels i am sure that any type of dialy driving would be out the window!! this isnt my daily even though i drive it often i give it no mercy.
Old 09-10-2010, 02:49 PM
  #47
amadeospike's Avatar
What heads are u going to use skeet?
$A_Money$81
03-27-2023 10:25 AM
Go5.3tt06
25
09-04-2016 10:25 AM
Lthompson
10-02-2015 12:45 AM
jscherbs
09-30-2015 07:54 AM
norris_83
09-09-2015 04:14 PM
Quick Reply: DBrods dyno #s and graphs. 7xx
