Dyno Numbers
13* of timing is giving up a lot of power, you need more timing if your going to make more power. Race gas, e85, or meth will get you there. Don't think your gonna get there on just pump gas. 5* of timing will make a lot more power!
WG's don't make power... They restrict power I've seen 1100hp made with a 38mm WG in the same location as yours.
11 Second Truck Club
Those are still good numbers, I agree on the fuel though. 16 psi is s lot on pump gas, my truck with very similar setup except smaller cam and smaller turbo made 650/646 on a low reading dyno dynamics at 13psi and 21* timing with e85 and meth. Your setup has lots of potential as is, just need a way to get another 4-6* timing in there and it will be a big difference.
DynoJet
No, I think .95 AR as not sure.
Thanks!! Gotcha! Also, U see the dyno graphic show tq ?? I think may explain the reason for the torque falling off so badly?? My cam comp 926's are 129lbs on the seat. My friend told me that is no where near enough seat pressure for a turbo @ 15lbs of boost. You should be in the 160lb seat range.
You are probably floating the valves.. Not bashing, my friend just trying to help.. hard to believe him or not.
you need to change to new 925's would of been much better with the seat pressure @ 141 on the seat.
Im stay with 926. I don't know what different between of valve springs numbers for 926 and 925??
Thanks!! U have good numbers!
John who tuned on my truck and He explained me reason he don't want to add more than 13* timing. but i want to add few * timing. because I know he is being conservative because its not his and i'm a customer. he has timing on the low side to make sure it doesn't detonate and break something cuz i dont hear it if it starts to detonate so i do. He want make sure my motor is safe. I know my motor will not break but unless have 317 head cylinders are stock. I wish i could have 317 heads to port to get better flow!
I would recommend something like an aeroforce scangauge or similar that can show you if you get knock, you mount it anywhere you could mount a boost gauge etc... Looks like you have a pretty well thought out combination of parts, should make good power with a little tweaking of the tune.
All right, I understand. no plm. so meth, If u can explain me for meth how to help turbo make more power ?? Where I can find meth ??
