Dyno Results
#21
Ouch, what mph were you at on the dyno when the shaft came apart? A couple hemi owners have had there's gernade on them when running 122mph+. Long drive shafts like the ones on a truck at those speeds can flex too much and gernade.
#22
It broke at 119mph according to the Dyno graph. I could feel the truck starting to vibrate during the dyno run but I didnt think that my driveshaft was going to break.
#24
what a rush!
Originally Posted by bradazz
I dont know, The guy told me that the steel DOM is what he would buy if he was in my shoes so I will take his word since that is all he does is work with driveshafts. BTW the video is looking good! Later.
I have the stock 2pc dana-spicer 3.5" steel driveshafts and they are safe to 6300/7000 rpm respectively according to dana-spicers critical speed chart and my local driveline shop. the 4" DOM reccomendation sounds like a good one to me
#25
I had a pinion angle problem that caused my driveshaft to let go at 141 mph on the dyno...but what's interesting about that is, I had noticed some vibration at 70 mph ever since I lowered the vehicle.
If your shaft let go at ~120 mph, let me ask - did you notice vibration at 60 mph, however slight? They are harmonics of each other, which means that a vibration at 60 mph reappears at 120 mph, only worse.
Make sure you don't have a pinion angle issue. The results next time with a steel shaft might not be so pretty.
#26
Yea I did not check the pinion angle after I installed the Hotchkis 2-4 drop but I will be checking it after I get the new driveshaft installed. To tell you the truth I didnt really notice any vibration except for when I got up to about 110 and then I felt a slight vibration. Thanks for the heads up, I heard that the pinion angle should be between 5-7 degs? Let me know if this is true. BTW, What kind of driveshaft did you get?
#27
When I finally had my angles looked at (well after my 2/3 drop and right after the driveshaft blew up), my transmission output shaft aimed down 4 degrees, but the pinion aimed up at 7 degrees. This fully explained the driveshaft incident.
After installing longer lower control arms (I had a 5-link in the Avalanche), the new pinion angle was then down 3 degrees. This was actually ideal, since applying Radixed torque actually moves the pinion up a degree or so, making the angles equal (4/4) under heavy torque load.
I ended up getting a stock replacement driveshaft. With the pinion angle correction, there was no problem after replacement.
Hope this helps. Definitely get it looked at by a shop that knows what they're doing.
#28
Originally Posted by TBSS
The pinion angle should be opposite and equal to the angle of the transmission output shaft. For example, if your transmission output shaft faces downward at 5 degrees, then your pinion should face upward at 5 degrees.
jscherbs
09-30-2015 07:54 AM
norris_83
09-09-2015 04:14 PM
