Dyno sheet (05 SSR 6 Speed) Magnuson Products
#35
Destroyer of Transmissions
Originally Posted by 2005SSR6Speed
Keep in mind that this is completely stock other then the Supercharger. I still have to do LT Headers, Full Exhaust, Intake Mods, 4.10 or 4.56 Gears then I will probably need some different pullies for the back of the supercharger to get the boost at 6-7 psi.
I need to do something about the traction first. It will still launch pretty good out of the hole from an idle and once you are moving it stays put real good. I just want some stickier tires that are a little wider (335/30R20), these are actually 1" shorter so it will effect the feel also.
#36
FormerVendor
I am going to wait on the gears till I figure out the height of the new rear tires I get. The stock tires are 295/45R20 at 29.2" tall and most of the tires I am looking at 335/30R20 are around 28" tall so it will make a difference. It has 3.73 gears right now so I think 4.10 will be good with the lower profile tires.
#38
what a rush!
Moregrip - It sure does pull hard in the upper rpm's doesnt it. I was a nice 6000 rpm 1-2 shift with the tires breaking loose a little.
Seriously though, it pulls like a raped ape! that 1-2 shift was nice, ****, you only need 3 gears now
