Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Dyno Time...Guessing Game
Old 01-14-2011, 11:22 PM
  #31
11 Second Club
Phantom's Avatar
Old 01-15-2011, 12:14 AM
  #32
13 Second Truck Club
LS1FREEK's Avatar
Do you have a vs rpm graph instead of speed? I would like to see that That's alota power for the setup!
Old 01-15-2011, 09:17 AM
  #33
11 Second Club
Phantom's Avatar
I have a 30" tire, 4.56gears, and the pull is in third gear. You can do the math from there if you'd like. I did t get an rpm graph but I can probably get one next time I'm there
Old 01-15-2011, 09:34 AM
  #34
11 Second Club
Phantom's Avatar
We made a quick motor pull just to make sure the a/f was close. I had a goal I wanted to see before we left and didn't think the .062 jet would get us there(500rwhp) So we put in what we thought it would take and ended up with a .073 nitrous jet which netted the 575rwhp. Come to find out, we could have probably done it with the .062
It helps that I have probably one of the best nitrous tuners in the area as a buddy. Most people probably wont see the. Same results as I did
Old 01-15-2011, 09:44 AM
  #35
11 Second Club
Phantom's Avatar
Most of you would **** bricks if you seen what a/f ratio was on that nitrous pull
Old 01-15-2011, 09:54 AM
  #36
JoeyGC5's Avatar
10.2 or 13.6?
Old 01-15-2011, 12:51 PM
  #37
11 Second Club
Phantom's Avatar
I'll let you all speculate even more...I only made 342rwhp on motor...
Old 01-15-2011, 07:48 PM
  #38
Jake99's Avatar
Thats a damm good setup you got there man. What is a 72.. 200 shot? looks like you picked up more then that! Good cam and good tuning. Btw Ment nothing bad numbers just seemed way hi for a 150 shot.
Old 01-15-2011, 08:10 PM
  #39
Red Truck's Avatar
It was a CLEAN 200 shot. The naturally aspirated power is very deceiving on that truck because all we were concerned about was nitrous. So the motor pull still had cold plugs, and was a 2nd gear pull. Plus the tune for straight motor was "put it in and go" type deal.
On something that is nitrous specific (cam, tune, converter etc)... The power all motor doesn't concern us, and frankly will rarely see the truck raced all motor. Which is exactly why the engine makes that much power on the dope.
There is more power in this combo on the same jet, this dyno was done with 100% pure pump gas. With the e85 (converting soon) , and a colder plug we will be able to stick a little timing in it and reliably make more power. Because of the gas and plugs we were very conservative on the timing.
Old 01-15-2011, 08:40 PM
  #40
LS1FREEK's Avatar
Good job Danny! I'm very impressed with the setup, man with that .72 pill, I'll bet flipping that switch will scare the **** out of just about anyone. Can't wait to see some new times with the big pill.
Quick Reply: Dyno Time...Guessing Game
