Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
"DYNO TRUCK LIST" (DTL)
Old 10-28-2007, 06:56 PM
  #201
8ALTNG's Avatar
Originally Posted by ranwalk
I dont think he should post yours until you get a hight boost pull
8ALTNG is offline
Old 10-28-2007, 06:58 PM
  #202
8ALTNG's Avatar
Originally Posted by moregrip
Parish still holds the top spot by alot
I wonder when someone is going to change that.........
8ALTNG is offline
Old 10-29-2007, 02:44 PM
  #203
04Denali's Avatar
04Denali is offline
Old 10-29-2007, 05:19 PM
  #204
8ALTNG's Avatar
Originally Posted by 2004Denali
I second that
8ALTNG is offline
Old 10-29-2007, 05:36 PM
  #205
single digit dreamer
parish8's Avatar
i can change that.
parish8 is offline
Old 10-29-2007, 05:44 PM
  #206
04Denali's Avatar
04Denali is offline
Old 10-29-2007, 05:49 PM
  #207
parish8's Avatar
lsx block, 6 bolt heads and 25psi and my numbers will be smoked. might be able to do it with a lot less boost depending on the heads, cam and driveline.
parish8 is offline
Old 10-29-2007, 05:55 PM
  #208
8ALTNG's Avatar
so were you just saving those number for a time like this
8ALTNG is offline
Old 10-29-2007, 06:00 PM
  #209
GFYS and STFU
Spoolin's Avatar
When is that from? I thought your truck is still in pieces and you've been working on your new project car and all! How much do you think is left on your truck's 408?
What's that max boost number is that 24 looks like 28??
Spoolin is offline
Old 10-29-2007, 06:54 PM
  #210
parish8's Avatar
those numbers are from about a year ago. i posted them up then but didn't post them to the dtl thread. >> https://www.performancetrucks.net/fo...highlight=1055
as far as what will the 408 take. i am not sure. good chance it wont take the 1055rwhp in the real world. i couldn't seem to get any more power than enough to run low 10's no matter what i tried but my fuel system was marginal. now that is fixed and it might be ready to go farthur but it might just be on the limit of keeping 4 bolt heads down.
the truck is 100% together, went to the local 1/8th mile track last friday for some 7.0 index racing. made it thru one round and got killed on the light in the 2nd round.
street tires, pump gas, thru exhaust(including wg exhaust), full weight, meth and at 14.5psi ran 6.99 at 103.
you can see the boost numbers on that thread i linked to.
parish8 is offline
Quick Reply: "DYNO TRUCK LIST" (DTL)
