Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Hitting the dyno tonight, any guesses?
Old 09-22-2015 | 11:54 PM
  #101
BlackGMC's Avatar
Resident Retard
Old 09-23-2015 | 12:39 AM
  #102
FFDP's Avatar
Old 09-23-2015 | 07:49 PM
  #103
George C....'s Avatar
Formerly ScreamingL
Originally Posted by AKlowriderZ71
That's not YOUR truck, it's not a 1.0-1.3 short time that you keep hammering on, and it's not even a GMT800/900 chassis.
So, I will ask again. What have you accomplished with YOUR truck on drag radials George? I don't care to hear stories about what somebody else you know, or read about on the internet. Talk is cheap. Put up or shut up.
i posted up a truck i put together and made passes in on a 315 radial
as for my silverado it hasnt made a pass in over 3 years as its currently under a full out build and is being setup to work on radials
now i posted a slip of a truck on a 315 radial with just rolling into throttle netted a 1.50, anyone in the posting done the same?
Old 09-23-2015 | 08:50 PM
  #104
BlackGMC's Avatar
Resident Retard
I think his point really was on a chevy truck chassis. I dunno the difference between a ford and chevy chassis.
Old 09-23-2015 | 08:59 PM
  #105
Formerly ScreamingL
I own both and have built both...hell my silverado has lightning coil springs and my lightning has silverado front shocks on it
They are very similar
Old 09-23-2015 | 09:12 PM
  #106
BlackGMC's Avatar
Resident Retard
They might be very similar i cant argue that because i honestly dont know. But are they the exact same? Since you seem to be the only one referencing lightnings that does not help a chevy dominated site.
Old 09-23-2015 | 09:14 PM
  #107
03sierraslt's Avatar
You guys have really derailed this thread. Just saying. OP, congrats on the numbers.
Old 09-23-2015 | 09:17 PM
  #108
Formerly ScreamingL
Nothing is exact but they could be cousins....same suspension setup works for both...weight is very similar
Hell could mount my LS motor in the fords frame using ford mounts or vise versa
A rcsb lightning or ford would share more suspension setup with a rcsb silverado then a extracab silverado would
Old 09-23-2015 | 09:58 PM
  #109
Wolftrk99's Avatar
you guys have really derailed this thread. Just saying. Op, congrats on the numbers.
x2!!!
Old 09-24-2015 | 06:54 PM
  #110
JordanH's Avatar
Restricted
Originally Posted by Gadgetized
I will finally be strapping the truck down tonight. Everything in the sig, E85, about 22 PSI, timing is currently at 18.5 degrees, B8EFS plugs gapped at .022, and I will be removing the air filter. What gear should I have it in? Still up in the air about locking the converter. Any other suggestions or input?
Have you always ran the br8ef's?
Quick Reply: Hitting the dyno tonight, any guesses?
