Hitting the dyno tonight, any guesses?
No meth, juat a cheap ebay wet intercooler. I made a heat exchanger out of a radiator I cut apart. I use a lightning pump, and a reservoir I made out of sheet aluminum. It usually stays right at ambient unless I start making boost, but doesn't climb too bad. Then one I'm doing for my Chevelle is pretty big wet one though.
I don't drive the truck every day, but I do quite often. I'm not even afraid to get caught in the rain. The best part is I made it flex fuel, so I can put any gas in it and the timing and AFR are automatically adjusted. It is fun to drive.
121 was on the dyno so it wasn't a long pull, I will have to check a log to see what a run was. But I know it wasn't too high. I like the wet intercooler.
I've been intrigued by A/W intercoolers because of their size and versatility in terms of placement. Piping length is often reduced as well compared to air-to-air. However, I chose to stay A/A. Less complex.
