LQ4 + 862 heads + TSP CHOPacabra cam
Most likely, but I am going to punt. I'm going to swap the converter next. It was doing weird stuff on the dyno when i locked it. On the street I notice it shuddering a little bit when it locks up sometimes. If no improvement, I'll change the cam and heads. I have a really nice set of 799s touched up by AI just sitting in my spare bedroom.
The more I look at flow numbers of factory cylinder heads in stock form... I think I F'd up using those 862s. Too much hype on the Internet saying they are they the best thing since sliced bread. My experience with them has been lackluster. I am not a fan and would not do it again.
On the cams, if my math is right:
TSP CHOPacabra = +2 overlap
my old EPS = -7 overlap
The Sloppy best = +1 overlap
Going from -7 to +2 overlsp, despite the roughly 1 point in static compression increase explains some of the TQ loss. I mentioned the "best cam" because I have one and am most likely going to pair it with those AI 799s. My only other cam option is a Summit 218/227 .600"/.600", which is -1.5 overlap.
I am still going to change the tq converter and go back to the dyno to see if that was part of the issue. Kind of a give it one last chance. But, I'm pretty much dead set on swapping the heads and cam for something different.
Custm2500's Rude Friend
The following 2 users liked this post by 1FastBrick:
Bluecollar Hotrods (12-28-2022),
strutaeng (12-28-2022)
I have a contact at Cam Motion when i order cam for a setup. I tell them all the specs and they grind a cam and ship it. They have all the cool stuff to know the details. Havent been dissapointed yet.
makes children cry
The Sloppy best = -1 overlap
if you've already got some worked 799s, then i'd say mill a few thousandths off, get new pushrods, and let it eat.
Goals? Make decent power, maintain some drivability. My truck is 4600lbs and some change w/o driver, 4.10s, will have a converter and supporting mods. 336rwhp just isn't going to cut it, I'd like to be around 375-380
Just so every one is on the same page...
Summit Racing 8720R1 Camshaft,
Stage 2, LS Truck Swap Cam, High lift version, 218/227 .600/.600 , 112+2
So this is a Stock LQ4 with the 8 cc dish piston.
Depending on your out of the hole piston measurement and what gasket you use, You will be around 10.25:1 compression ratio with 63 CC
Curious if they removed the casting flash where the seats enter the bowel in the head?
Should be a STOUT combo and I believe you will net what your looking for within 10 HP at the wheels.
68Formula (01-20-2023)
As promised, changed the converter last weekend - went back to the dyno today. And... absolutely ZERO gain. Kind of what I expected. We made a few changes trying to squeeze more out, but it has no more to give.
So my thoughts, I would never do stock 706/862 heads on a 6.0L again. I don't care what the engine dyno on the Internet says, real world experience... hard pass.
Now, just need to figure out when I can do the heads and cam swap + retune next month. I'd also like to make a few passes with this set up first. I'm going to guess mid 13s, maybe it will surprise me.
Blue lines are current, red is previous with the factory converter.
