Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
LQ4 cam only
Old 04-30-2010 | 08:22 PM
  #21
mhotrodscooter's Avatar
Originally Posted by PathfinderJr
Nah, that's not the reason. I have no doubt those numbers are legit, its just when the graphs don't cross at 5252 rpm (for which there is a mathematical reason behind going all the way back to what defines 1 hp), the accuracy of the dyno comes into play, but this effect will also come if the vertical scaling has been adjusted, which is has in this case.
In short, don't lose any sleep over it. I don't like it when the vertical scales are different for hp and torque because I like to directly compare the respective curves of each, but oh well, it's how they did it. You just have a really torquey engine I guess.
Ok I understand now! We try to get a good pull but it would downshift into 2nd & then up shift! So maybe oneday I can go meet up with Wheatley & he can work on it so I can get a good pull with converter locked & not downshift!
Blue03sss
03-07-2019 05:06 PM
GrooveCityZ71
08-31-2015 12:05 PM
darnie
08-10-2015 10:25 AM
jaypowe11520
07-29-2015 07:59 PM
NuckenFuts
07-09-2015 08:45 AM
Quick Reply: LQ4 cam only
