Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
LQ9 cammed dyno
Old 01-26-2021, 08:37 PM
  #21
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
I'd say the exhaust is the bottleneck too.
I used to have almost the exact same setup: LQ9, SS2, PAC 1218's, 4.7pr, LS7 lifters, stock 317's, stock TB and intake, built 4L60, 3200 stall etc. The difference between the two is the Speed Engineering 1-3/4" headers with their true duals. Even before I tweaked the tune I could easily hit the limiter set a 6800 RPM. The screen shot below shows 6,434 RPM letting the transmission automatically shift from first into second gear (when I had 3.42 gears). The timing was only set at 24* total advance at that time.
Old 01-26-2021, 10:11 PM
  #22
Custm2500's Rude Friend
1FastBrick's Avatar
So went back and looked at the final numbers my buddy sent me. I don't have the sheet.
Fresh LQ9 .020 over, CNC ported 241's, Same Cam from Jegs, a 90mm truck intake 1 year only truck manifold from a 2005 Trailblazer flowing Through Cast iron factory manifolds and Replacement Catalytic Convertors and magnaflow catback exhaust. Also has a cut out on it.
2000 or 2001 Silverado running a 2002 operating system IIRC 12212156 OS with flex fuel enabled.
365 HP / 382 Lb Ft at the wheels on a Dynapac Hub dyno... and it's within 100 miles of Sea level.
chubbza5 (01-26-2021)
Old 01-26-2021, 10:44 PM
  #23
chubbza5's Avatar
Hey Man, thank you for the feedback. Watching your truck on youtube was one of my inspirations for the build. Your garage floor is unmistakable. I know you have since changed from that cam but I agree I think there's more to be had. I have a true 3" flow through on order. I found mandrel bent sections leading into the flowmaster that are less than 2.5"... Also picked up a TBSS intake complete today and have a 90mm DBC throttle body ordered. I'm going to let it breathe and see where it's at. Can't believe you replied, probably my top influence for building this truck.
arthursc2 (01-26-2021)
Old 01-26-2021, 10:46 PM
  #24
arthursc2's Avatar
Received 1,502 Likes on 1,101 Posts
What's special about an 05 Trail Blazer intake manifold? First I'm hearing of this and am curious
Old 01-26-2021, 10:47 PM
  #25
chubbza5's Avatar
Not as fresh lq9, but there was still cross hatching on the cylinders so I went with it. Picked up a TBSS cathedral port intake tonight. Figuring with no cats and a straight through exhaust, 90mm TB, I'll pick up a bit. Considering some ported 706's, they put up some surprising numbers given the compression boost.
Old 01-26-2021, 10:53 PM
  #26
chubbza5's Avatar
I don't think anything other than it's def a cathedral port intake.
Old 01-27-2021, 06:43 AM
  #27
arthursc2's Avatar
In his post he said it was a 1yr old thing, at least that's how I read it
Old 01-27-2021, 11:45 AM
  #28
100% Redneck
RedXray's Avatar
What year TBSS?
2008 and earlier TBSS intakes (12580420) have the correct MAP sensor hold down and PCV nipple. You can use the 2009+ intakes with a little adaptation to the MAP sensor and fabbing a hold down.
The TBSS intake in the video is the 2009+
The 2008 and earlier intake below with the correct MAP & PCV hose connection.
dantheman1540 (01-27-2021)
Old 01-27-2021, 12:11 PM
  #29
arthursc2's Avatar
I don't know anything other than what's posted. If I am reading this wrong, someone feel free to correct me; but this post implies that a '05 Trailblazer manifold is 1 MY only and I'm trying to determine what makes it special. Carry on
Old 01-28-2021, 01:14 PM
  #30
1FastBrick's Avatar
That is correct. It is a 1 year only manifold that resembles a standard truck manifold but features a larger 4 bolt Throttle Body opening.
Nothing special other than it was available at the Junkyard at the time. The TBSS style has not come up in local yards and I refuse to pay new Prices for used parts.
Quick Reply: LQ9 cammed dyno
