LQ9 cammed dyno
#21
100% Redneck
I'd say the exhaust is the bottleneck too.
I used to have almost the exact same setup: LQ9, SS2, PAC 1218's, 4.7pr, LS7 lifters, stock 317's, stock TB and intake, built 4L60, 3200 stall etc. The difference between the two is the Speed Engineering 1-3/4" headers with their true duals. Even before I tweaked the tune I could easily hit the limiter set a 6800 RPM. The screen shot below shows 6,434 RPM letting the transmission automatically shift from first into second gear (when I had 3.42 gears). The timing was only set at 24* total advance at that time.
#22
Custm2500's Rude Friend
So went back and looked at the final numbers my buddy sent me. I don't have the sheet.
Fresh LQ9 .020 over, CNC ported 241's, Same Cam from Jegs, a 90mm truck intake 1 year only truck manifold from a 2005 Trailblazer flowing Through Cast iron factory manifolds and Replacement Catalytic Convertors and magnaflow catback exhaust. Also has a cut out on it.
2000 or 2001 Silverado running a 2002 operating system IIRC 12212156 OS with flex fuel enabled.
365 HP / 382 Lb Ft at the wheels on a Dynapac Hub dyno... and it's within 100 miles of Sea level.
chubbza5 (01-26-2021)
#23
arthursc2 (01-26-2021)
#25
#26
#28
100% Redneck
What year TBSS?
2008 and earlier TBSS intakes (12580420) have the correct MAP sensor hold down and PCV nipple. You can use the 2009+ intakes with a little adaptation to the MAP sensor and fabbing a hold down.
The TBSS intake in the video is the 2009+
The 2008 and earlier intake below with the correct MAP & PCV hose connection.
dantheman1540 (01-27-2021)
#29
#30
Nothing special other than it was available at the Junkyard at the time. The TBSS style has not come up in local yards and I refuse to pay new Prices for used parts.
