Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
LQ9 cammed dyno
Old 01-28-2021, 04:04 PM
  #31
Custm2500's Rude Friend
1FastBrick's Avatar
These are all I currently have.
Old 02-09-2021, 08:15 PM
  #32
chubbza5's Avatar
What's up everyone! Quick update, picked up a (pre '09 I believe) TBSS intake and a 92mm TB. Made my first PTFE fuel lines, what a pain in the a** that is but very worth knowing it won't fail. Used the little olive bushing style you have to feed under the stainless, very tight. Also picked up a 3" MBRP flow-through style exhaust and got rid of the chokemaster. Really feel a difference already pre-tune with it.
I also found out the tuner was using SAE numbers instead of STD which I'm told is what most DynoJet tuners use, when he switched the sheet over to STD it made 327hp/340tq. Shooting for 350whp+ when I go back, I think the exhaust has already gotten me most of the way there. I can't get through 1st gear no matter what I do now, I'll blow the tires off or the trans will shift early if I'm not WOT, need to adjust that a bit. Spinning into 2nd is fun though
@RedXray can probably confirm the intake year.
The following 2 users liked this post by chubbza5:
arthursc2 (02-09-2021), RedXray (02-12-2021)
Old 02-09-2021, 08:23 PM
  #33
arthursc2's Avatar
Received 1,502 Likes on 1,101 Posts
Nice man! Looks good from here!
Old 02-12-2021, 02:21 PM
  #34
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Looks good!
Yes you have the 2008 or earlier, that simplifies the MAP & PCV.
Old 02-12-2021, 05:17 PM
  #35
1FastBrick's Avatar
Originally Posted by RedXray
Looks good!
Where they in a different position on the later intakes?
Old 02-12-2021, 07:41 PM
  #36
100% Redneck
RedXray's Avatar
2009+ use a different MAP sensor and hold down. You can't run the later MAP on a Gen3 without scaling the tune. The intake MAP hold down is different too so mounting the early MAP can be an issue. The 2009+ intake does not have the PCV nipple... you have to buy the GM nipple hose assembly to make it work. The older intakes all you need is a piece of hose for the PCV.
Newer style MAP (center) beside older MAP
Newer TBSS without the PCV nipple
Early Intake with PCV nipple and correct Gen3 MAP port/hold down
Old 05-16-2021, 12:18 PM
  #37
10 Second Club
Not as fresh lq9, but there was still cross hatching on the cylinders so I went with it. Picked up a TBSS cathedral port intake tonight. Figuring with no cats and a straight through exhaust, 90mm TB, I'll pick up a bit. Considering some ported 706's, they put up some surprising numbers given the compression boost.
I'm guessing you never got a chance to redyno and see if any of the changes helped?
Old 06-28-2021, 10:41 PM
  #38
chubbza5's Avatar
Hey 86... I did get a new 3" exhaust, TBSS intake mani, 92mm TB, new fuel setup. Haven't dyno'd it yet... haven't had time for it tbh. I did get a quick retune and it's got a ton more grunt, top end feels about the same. I want to get the fuel pump done before I spend the money to spin it again. I will update when I get a video, I hate half threads.
BlackAlh
01-26-2021 03:05 PM
Petey62782
01-21-2011 11:34 AM
CalSpeedPerformance
41
01-17-2010 07:35 PM
PEDRO
10-10-2005 10:27 PM
Quick Reply: LQ9 cammed dyno
