Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Made 668rwhp on 12psi
Old 10-18-2011, 09:41 AM
  #31
dlt76028's Avatar
Old 10-18-2011, 05:29 PM
  #32
GFYS and STFU
Spoolin's Avatar
Originally Posted by dlt76028
Thanks David...I'm gonna give you an A for effort on this one!!
Btw...when you coming out to LA? Why is it that I'm always the one coming out to Texas?
Old 10-19-2011, 02:07 AM
  #33
GFYS and STFU
Spoolin's Avatar
I'm having problems keeping my plug wires from popping off. Anyone have any tricks or tips for keeping plug wires on the spark plugs? I've already made up 3 new wires to replace some burnt ones and those are popping off. Ugh!
Also in HPT, is it the scanner that can tell you which cylinders aren't firing, and if so what box/table is it that tells me which cylinder is not firing?
Old 10-19-2011, 02:16 AM
  #34
Mod with training wheels
smokeshow's Avatar
Yes it is the scanner. Log your current misfire counts for each cylinder. Should be under engine diagnostics.
Old 10-19-2011, 08:16 AM
  #35
I have a gauge for that
Atomic's Avatar
current misfire and misfire history is also useful....you will go over the 24bit limit but refresh rate isnt as important when logging misfires.
Old 10-19-2011, 12:26 PM
  #36
smokeshow's Avatar
Gen 4 ECMs FTW. They'll take 40+ bits and have no drop in resolution
Old 10-19-2011, 12:35 PM
  #37
Atomic's Avatar
son of a...
Isnt jules using a gen3 though?
Old 10-19-2011, 01:58 PM
  #38
smokeshow's Avatar
I assume so. Ability to log a lot of PIDs isn't that much incentive to swap to a new harness, although it does make tuning much easier. I use a single config file for almost everything lol.
Old 10-25-2011, 08:35 PM
  #39
Stoichiometric's Avatar
Congrats on getting the truck running right! For the plug wires...after you have pushed the wire onto the plug try squeezing the boot a little bit to make a gap to let trapped air out. If you can listen closely you will hear some air pressure escaping. If that pressure is trapped in there it may be helping to pop the wires off. Same is true for the coil side.
Vortec350ss
01-12-2016 10:36 PM
Chewy07
11-14-2015 09:46 PM
Velocity1
10-02-2015 08:01 AM
The_W
10-01-2015 02:35 PM
Quick Reply: Made 668rwhp on 12psi
