OK, 551 hp and 647 lbs at 17psi.
#23
The intake is on, I just need a fan belt, and I have to hook up a few hoses. My wife and son are sick and I am haveing a hard time getting back in there to finish up. The Responsibilities start kicking in.
#24
Well the truck is running! But not very good. I hooked everything up and my wideband is showing an extream lean condition. the injectors are not leaking, motor runs smooth untill I give it gas. It sound like a miss. I think I missed something. My vacume is normal! Is it possible to mix up the fuel lines, they both look the same?I have to look at it tomarrow. Wish me luck!
#25
did you check all your wiring and your coil packs. i had the main coil pack harness disconnected once and the truck fired up idles ok but when i gave it gas it would respond so much lol. i would say check all your wiring first ro everything. do you have a way to check your fuel pressure also?
#26
I think you are right! I think I may have something backwards. Fuel lines are right, I may have mix up the wireing. May be the injector conections. I am trying to find time to play with it. But the wife and kid are sick so I have to pitch in alot of time there. Thanks for the info.
#28
Ok! It was a loose injector wire. I Think I lost quite a bit of low end torque, I just drove it around the block. Just alittle boost, it did not feel as stong. I hope as I drive it around alittle more it will get better. I hope it just feels slower but is much faster, like when the I first test drove the 93 camero (auto/lt1). I didn't think it felt fast but it was alot faster than my mustang (5speed,5.0,bolt on's and gears) at the time. That camero kicked my *** everytime, I didn't understand it, it didn't feal that fast. Anyway, I hope it gets better, or looks better on the dyno and track!
#29
Did you use the truck rails and injectors? Did you cut the water pump neck and the alt bracket?
