Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Phoenix dyno results (thunder550, kbracing96, vanillagorilla)
Old 03-08-2006, 06:15 PM
  #21
11 sec. Truck Mod
TIM Z's Avatar
[QUOTE=kbracing96]Here's mine, Pretty happy with if for being a stock motor and only 7 lbs of boost. Although I need to find a load bearing dyno, as this dyno wouldn't load it hard enough tho build boost in the lower rpm as you can see in the graph. I thinh the funny thing in the graph is when the torque converter locked. Tune was pretty good (safe), EFILive showed A/F around 11.6-11.8 and was running about 17.5-18* of timing.
those are some great #s for that 4.8! GEN 3 ENGINES RULE!
Old 03-08-2006, 09:40 PM
  #22
TurboGibbs's Avatar
Originally Posted by thunder550
Ok here's my results.....
Somewhere around 365 rwhp / 410 rwtq. Take a look at my AFR's....way way rich. I think she's got something close to 390 in her if I can get the tuning right.
Hopefully Kyle and Todd will post up shortly too.
Great showing guys!
Thunder550, you've got a lot left in yours I know for sure. There isn't much difference in my old set-up and yours accept for you have a 5.3 and I had a 4.8. I made 80 rwhp and 79 rwtq more than you. My 5 speed has a little less drag than the auto though. Keep it up!
Old 03-08-2006, 10:09 PM
  #23
High on diesel fumes
thunder550's Avatar
Originally Posted by mjhoward
Great showing guys!
yeah but you were running 30* timing!! i'm only at a measly 17*. i definitely have more in it though.....
Old 03-08-2006, 10:40 PM
  #24
TurboGibbs's Avatar
from what I remember, going from 25-30* wasn't worth but 15-20hp.
Old 03-08-2006, 11:16 PM
  #25
thunder550's Avatar
Hmmm...well I'm getting ready to do the 90mm TB as well, so maybe I can get up into the 20's for timing.
Old 03-09-2006, 07:52 AM
  #26
vanillagorilla's Avatar
Yeah, try 5* of timing.
Old 03-09-2006, 08:50 AM
  #27
TurboGibbs's Avatar
My changes in timing were made slow and 1* at a time. We had to really custom tailor the rpm band with the timing. Above 6k the timing was only 26* to stay out of kr. Most of this tuning was done on the street on a 85+ degree day. Granted the 30* was excessive. At 31* on the dyno we got kr so we backed it down to just 30*. Then 2 weeks later in the middle of a warmer day I had 2 other guys in the cab for a joy ride and the weighed 230-250 each. That was an extra 500lbs load on the engine with a 1* buffer set up for a much lighter dynojet pull on a 55* evening. I think that was a recipe for disaster, don't you The strange thing is I saw no kr on my interceptor scanguage at all. It just hit sudden detonation when I shifted to 3rd gear It drove 40 miles home under it's own power and 3 pistons with chunks of ring lands missing
Old 03-09-2006, 12:02 PM
  #28
Geez, that's tuning to the ragged edge. I was refering to my truck only having 5* of timing TOTAL! If you look at my EFI live screen shot, you'll see that I had 11.5* at that moment, but earilier in the run you can see I only had 5*. Now that **** sucks. In fact I had more KR than timing. I need fuel in the worst way.
Hey Chris, can you give me some of yours?
Old 03-09-2006, 12:19 PM
  #29
thunder550's Avatar
You want gas? I got gas.....most people want me to leave, but if you want it it's all yours. Strange fetish though, not quite sure how I feel about that.
Old 03-09-2006, 12:41 PM
  #30
kbracing96's Avatar
l
l
l
l
Quick Reply: Phoenix dyno results (thunder550, kbracing96, vanillagorilla)
