Wow. Ok...so I see your basic setup in your first post. What kind of hot parts? What rear end? Suspension mods?
I've been thinking about doing a project truck, and this is pretty much what I had in mind. Very nice.
I originally had done a trick stage 3 kit. I quickly realized it was not going to make anywhere near the power I was interested in so I ditched everything but the log manifold. I added a tial mvr44 to the manifold just under the turbo (the way it should have been done), then I patched over the original waste gate hole (after the trick installed gate fell the **** off). I built my own 4 inch downpipe and exhaust with diesel dynomax muffler.
Rear end is the original rear end with a mini spool and stock axles. Suspension is completely stock 120000 miles shocks and all. The front springs have been heated with a torch to achieve ride height desired. Rear springs are removed all except one leaf and overload spring. Cal tracs and a 9 degree shim. Half inch preload and -4 degrees pinion angle.
