Tc76 365" dyno numbers
11 Second Truck Club
I forgot to add, this was the fourth pull and their fans really suck that blow at my intercooler. Run started at 105 iat and ended at 187! I have never seen them this high on the street. Run started at 21 deg advance and was down to a measly 10.5 at the end of the pull.
I would highly recommend it. As I've said before Jarrett (stock48) advised and supplied me with most of the engine related parts of my truck, and as you can see works pretty well even with not do optimal conditions (too small turbine side and iats pulling 10 deg on the top end.) His truck speaks for itself, mine runs pretty good on the street too. I believe if my iat's weren't pulling so much timing due to the shop having a household size fan, I could have broken 700hp, 10 deg is a lot in forced induction.
I have 74lb injectors with the stock regulator. Runs 58psi key on engine off (base). And goes up to around 61-64 at full boost. Need to go bigger, but I have only heard how sloppy the larger ones spray at low load.
jscherbs
03-24-2017 07:20 PM
rednekferlife101
09-14-2015 05:27 PM
norris_83
09-09-2015 04:14 PM
