Eastern VA, MD, DE, WV, PA, ME, VT, MA, CT, NH, NY, NJ, RI
Capitol Raceway Sun Nov 16th
Old 10-18-2008, 06:14 AM
  #121
Import Moderator
beastmode's Avatar
What are you on Bryan, a single 255?
Old 10-18-2008, 06:38 AM
  #122
sharpshooter's Avatar
Bryan nice run man.
It could be your pump.I don't know your set-up.What afr's were you seeing up top?
I started noticing my afr's rising at high rpm's the other day in the cooler weather and even more yesterday [coolest day in a while].The afr's have been good in the warmer weather.So I hooked up a mechanical fuel gauge and realized my single in tank Walbro 255 can't keep up the pressure at high rpm's.I'm going with an in tank Bosch 044 and I have to get it in before the 16th so I can run.
Old 10-18-2008, 07:16 AM
  #123
Moderately Differentiated
dewmanshu's Avatar
I could swear he has the inline 255 and stocker in the tank.
I bet your not. On your past scans, justin has your afr rock steady all the way through the run. If it did start to lean out, it would have to lean out pretty high to cause you to sputter IMO.
Old 10-18-2008, 07:47 AM
  #124
yeah mine is leaning out but not sputtering
Old 10-18-2008, 10:37 AM
  #125
Adkoonerstrator
XLR8NSS's Avatar
Mine gets up to 12.5:1 and does not sputter. I need to do something about that before the 16th also.
Russ - Why not try a voltage booster on your 255?
Old 10-18-2008, 01:49 PM
  #126
Baltimore Whore
Mangled03gmc's Avatar
Nice run Breeze, I think I am also running out of fuel, but not sure yet, have to send more logs to J. I am running Walbro inline, stock intanker...
John
Old 10-18-2008, 03:53 PM
  #127
11 Second Truck Club
Breeze's Avatar
I am runnin the inline 255 but thats not the problem. The problem is that Ive lowered the back of the truck 2'' shackles removed the overload spring and then runnin 28'' tires has messed with the gas gauge and it wasnt picking up it showed I had a 1/4 tank. lucky **** I am it went lean like 2 or 3 secs before the end of the 1/4 mile I am terrible at not remembering to keep an eye on my gauges Ive got to remember to glance over at them or its gonna cost me another motor I dont even want to go there again.
Old 10-18-2008, 03:59 PM
  #128
Baltimore Whore
I hear yah, when I am loging, for J it is freaking hard to watch the gauges, drive the damn thing at the same time.. Where was the gauge at as far as AFR?? mine showed 14-6
John
Old 10-18-2008, 04:18 PM
  #129
2nd fastest 5.3 ECSB
trever1t's Avatar
I need to set up a video camera in cab so I can see what my gauges are doing during track run...
Old 10-18-2008, 04:48 PM
  #130
Whippled 496's Avatar
Thats a pretty good idea actually.....LOL. To much **** to remember....
Make sure you lock in 4hi
Make sure OD is off
Go on last yellow
Hit 2hi right after you launch
look good for the ladies
watch the fuel pressure
watch the AFR
Keep an eye on KR
....to much stuff!!
Quick Reply: Capitol Raceway Sun Nov 16th
