Capitol Raceway Sun Nov 16th
#122
Bryan nice run man.
It could be your pump.I don't know your set-up.What afr's were you seeing up top?
I started noticing my afr's rising at high rpm's the other day in the cooler weather and even more yesterday [coolest day in a while].The afr's have been good in the warmer weather.So I hooked up a mechanical fuel gauge and realized my single in tank Walbro 255 can't keep up the pressure at high rpm's.I'm going with an in tank Bosch 044 and I have to get it in before the 16th so I can run.
#125
Adkoonerstrator
Mine gets up to 12.5:1 and does not sputter. I need to do something about that before the 16th also.
Russ - Why not try a voltage booster on your 255?
#127
11 Second Truck Club
I am runnin the inline 255 but thats not the problem. The problem is that Ive lowered the back of the truck 2'' shackles removed the overload spring and then runnin 28'' tires has messed with the gas gauge and it wasnt picking up it showed I had a 1/4 tank. lucky **** I am it went lean like 2 or 3 secs before the end of the 1/4 mile I am terrible at not remembering to keep an eye on my gauges Ive got to remember to glance over at them or its gonna cost me another motor I dont even want to go there again.
#128
Baltimore Whore
I hear yah, when I am loging, for J it is freaking hard to watch the gauges, drive the damn thing at the same time.. Where was the gauge at as far as AFR?? mine showed 14-6
John
John
#130
Make sure you lock in 4hi
Make sure OD is off
Go on last yellow
Hit 2hi right after you launch
look good for the ladies
watch the fuel pressure
watch the AFR
Keep an eye on KR
....to much stuff!!
