**1015 hp tvs 2300 boost only**
Old 04-06-2012 | 04:30 PM
  #21
Lucille's Avatar
Originally Posted by BlownChevy
Note the 390 CI too!!!!
At first I thought they must have gotten a LS2 rotating assembly from AES, but I see that this build was based on a LSX block. I'm guessing based on the 9,000 rpm in the article that this engine is much larger bore & shorter stroke than the AES 390.
Old 04-06-2012 | 06:34 PM
  #22
kbracing96's Avatar
I've said all along you need less C.I. to make more HP with a 2300. The blower can only flow so much air, you need RPM to get more HP. On a 427 the 2300 can't flow the air needed for 1000hp. Both motors will make very similar torque though. The 390 will just be able to make more HP cuz it can spin more RPM before the blower is done.
Old 04-06-2012 | 07:32 PM
  #23
stock48's Avatar
9 Second Truck Club
A 5.3L might go even higher if you could get enough head on it. Maybe a l92 block and 4.8 crank...
Old 04-07-2012 | 06:50 AM
  #24
old motorhead's Avatar
If my LS3 ever shoots craps, that's the motor that is going back in. Comes out to about 339 cubic inches (5.5L). If you use the longer 4.8L con rods, you can even use an off the shelf piston.
Old 04-07-2012 | 03:07 PM
  #25
idahoblkss's Avatar
did any body notice the crank pulley lol 50% overdriven ( not really but just sayin') . i would like to see what a f1 would do on that set up. good job thou guys allot of hard work went into that.
Old 04-07-2012 | 10:46 PM
  #26
VegasLSX's Avatar
Wow! Congrats!!
Old 04-08-2012 | 10:02 PM
  #27
TXBlownTBSS's Avatar
10% larger than a stock crank pulley.
Old 04-09-2012 | 04:15 PM
  #28
Here's a new video of joes 390/2300. It's got some more details pics of the engine and parts.
LSX390 TVS2300 1015hp and 936tq - YouTube
Old 04-09-2012 | 05:23 PM
  #29
dmelvin's Avatar
That maggie sounds like a damn jet engine.
Old 04-09-2012 | 06:36 PM
  #30
Lucille's Avatar
Awesome! Anybody else notice the belt stretch/wobble in the 1:50s and 2:20s during the video? Also, was the low rpm surging at the start of the video the dyno operator playing with the throttle or the camshaft?
