04 4.8L 5MT RCSB SC build
Old 02-13-2013 | 10:44 AM
SIXJAK's Avatar
Here's some more pics.http://Name:  BB8D7F0B-D055-4984-8F41-17FDC5FC76AF-1368-0000012E61A607D9.jpg
http://Name:  284AA7EA-2F6C-4049-8338-4064E7DD7F3E-1368-0000012E5BE14C87.jpg
http://Name:  E7DB8997-7E15-45D9-B107-937F84B9A6F7-1368-0000012E20B23678.jpg
http://Name:  B68900AC-BF51-412F-81CE-5E466755C102-636-000000487AC115B8.jpg
Old 02-14-2013 | 09:52 PM
foose04's Avatar
I like, clean little setup and sharp truck for sure.
Old 07-27-2013 | 09:13 AM
SIXJAK's Avatar
It's been a while since I last posted. Since my last post, I've had the following work done.
License plate flip up kit and tow hitch installed.
Eaton posi rear end
Swapped 3.41 stock gears for a set of 3.73's
Stage 3 Centerforce clutch
Corsa side exit catback exhaust just came yesterday as well as my 3.4" pulley. Replacing the 4.1" pulley.
I also picked up a set of factory steel exhaust header gaskets and new bolts. The cork garbage that came with the PaceGhettos already took a dump so hopefully they fix the leak.
Ordered cam, valves, lifters, oil pump
and E-fan kit.
The above will be installed starting on Aug 1
Old 07-28-2013 | 01:54 PM
oakley6575's Avatar
How much boost are you running with the pulley swap?
Old 07-28-2013 | 06:17 PM
Blackpanther99's Avatar
Looking good! You need efans though! Lol
Old 07-29-2013 | 03:25 AM
SIXJAK's Avatar
Currently I'm running about 5-6 lbs of boost. Very safe level you don't even hear the blower ever lol. With the pulley swap I'm hoping to get to about 11-12#'s.
Yep that's on the list of parts going in starting Aug 1. Also installing an 80mm TB.
I'll definitely be posting up some pics.
OHsixLS3
12-27-2016 09:30 AM
thunder550
10-08-2015 04:53 PM
USMCvet0311
08-14-2015 10:28 PM
black00chev
08-12-2015 01:56 PM
Quick Reply: 04 4.8L 5MT RCSB SC build
