1/4 mile times with 408 & Radix?????
Old 08-12-2010, 05:50 PM
MikeGyver's Avatar
If it's not intercooled, he's doing real good.
Old 08-12-2010, 06:43 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
It is not intercooled.
Old 08-12-2010, 10:26 PM
Mod with training wheels
smokeshow's Avatar
You alaska guys and your cold air.... lol
Old 08-15-2010, 11:38 AM
02'Z71ONDUBZ''s Avatar
13.8 with a stroker and blower?
x2...
Old 08-16-2010, 09:08 PM
40Mike's Avatar
My 2005 Silverado RCSB 5.3 with stock heads, stock cam and all other stock internals plus bolt-on’s in the form of; a Maggie 1900 with 3” pulley, DynaTech long tubes, 90mm TB, Snow Performance Meth spray, a Ford 9” with 3:89’s, Tru-trak and M&H 12.0/29.0 / 15 slicks runs in the 12’s with a low of 12.53 and a 60’ of 1.71 – not bad for a bolt-on 5.3 pulling 4,620 lbs.
Hardy Handshakes, Swede
Old 08-18-2010, 10:05 AM
NightmareTBSS's Avatar
I figured a 408 would alone put him in the upper 12's with a good set of DR's. With a blower on top of that its near a stock tbss. Do you think the blower is hurting his e/t?
Old 08-18-2010, 10:19 AM
Praise The Lowered
RibeiroBJJ's Avatar
Originally Posted by 02'Z71ONDUBZ'
x2...
X3......hmmm...
Old 08-18-2010, 12:15 PM
MikeGyver's Avatar
Originally Posted by NightmareTahoe
... Do you think the blower is hurting his e/t?
If he is using the Whippletronics, then yes, absolutely. If he eliminated them and is using bigger injectors and a tune, then without an intercooler, his ET is probably not being hurt. The added bottom end power from the blower probably makes up for the loss on top for elapsed time. He would most likely MPH better in the 1/4 without that thing on the truck at all, pushing 200° air into his motor like it does.
Old 08-18-2010, 12:34 PM
No Whippletronics. Has 60# injectors and a Nelson tune. The truck is AWD on 32" street tires, and has 4 wheel steering, so yes it's heavy. Transmission has been "built" locally, I have no idea what's in it, and the converter is stock. Also has stock manifolds, cats, and stock cat-back.
kr1s
08-24-2015 05:34 PM
dantheman1540
07-29-2015 04:45 PM
therock
07-25-2015 09:23 AM
Choda
07-21-2015 03:47 PM
fcompean
07-15-2015 09:55 PM
Quick Reply: 1/4 mile times with 408 & Radix?????
