10-15 psi... what plugs?
the correct way to actually do it is put a cold enough plug to burn the cadnium off the strap, too cold and it wont burn off, too hot and it will look ashy, a 7 would take a ls motor to 800rwhp or so on gasoline, ive run tr6 heat range up to 1200-1300 flywheel hp on E85
i was originally planning on going with the BR7EF's so now i feel better about that, what are most of you gapping them at with your boost levels?
