100MM MAF and 4" intake for Radix
Moderately Differentiated
Originally Posted by j's01silverado
In your set up, once the MAF is maxed out, does the 2 bar map take over? Are they used together all the time?
Former Moderator :(
LPE MAF works great I have been using them on the engine dyno for while. It comes with a MAF transfer function sheet and be careful it will put a 10 lb boosted engine in the middle of the timing map so if you use to have 17 deg of timing at WOT you may have 24 now.
Notorious BIG
click
click
Former Moderator :(
The meter comes with a harness just solder and heat shrink the 3 MAF wires and solder the two IAT wires to the Magna Charger supplied IAT harness. You really don't need anything else
Notorious BIG
John, thanks for the quick reply. I have one more question for you if you don't mind. I know this is a hot topic but don't want to waste my money.
Since im boosted and using a 2bar map sensor is it worth it for me to use this 100mm maf with my 122 radix setup? I mean am i know the pcm does not reference the maf after 4k rpm's anyways so what is the advantage of this maf? i understand its 4inches in diameter and will not be a restriction but is that the only gain? I need to purchase a new maf anyways so i just want to know if i should just buy a stocker or this 100mm unit? Any explanation you could provide or advice you can give would be great.
if you need to get one anyways,and your okay putting the extra dough out, then get it. Emissions is gonna require you to have no SES light (or codes) and that means your are gonna have to enable the maf at least for the emissions. (unless you get the whole maf/2bar combo thing tuned)
i know you know, but your second sentence is confusing...open loop and maf have nothing to do with one another. You are currently SD after 4K rpm. Hell SD the whole time.
Just get it and get mad at it and sell it to me cheap! Nice pointer on the timing table crash.
Notorious BIG
i fixed my post. i was thinking one thing and typing another. thanks.
oh, btw dew, get online, i need to ask you something.
my reason for asking this question on the 100mm maf is this. If i buy one, i need to make a whole new air intake from the maf to the TB. With the stock maf i can use the radix intake tube. the price of the maf does not conern me because insurance is covering it anyways.
