100MM MAF and 4" intake for Radix
#22
what a rush!
Originally Posted by Holty
just remember, i'll also need to figure out a way to mount the 100mm maf to the airaid intake box. with all this custom work it might not be worth buying it. don't know?
#23
Notorious BIG
Originally Posted by moregrip
let me know what you want to do bro, I have a stock MAF I might be willing to part with as well
#24
what a rush!
well, i know for sure i want the intake tube off of you. now i'm thinking maybe stay with the stock maf, not sure yet. what are you using grippy? errrr i mean going to use?
why would you still want the intake tube?
#25
Moderately Differentiated
the 90mm TB, LPE 4" MAF, and custom intake setup
f-er is confusing isn't he? He doesn't even drink. seems he is going with the 4" (LINKY). I am curious of your intake setup as well grip. the maf to TB part.
#27
Notorious BIG
I want a stock setup to use until i can get this custom intake built and who knows if i'll even be able to figure it out. i don't understand how you get a straight piece of tube to bend in all the different directions you need to route it from the TB to the MAF, then to the air box???
#28
Josh,
I need to send you some pictures of my 3 custom intakes I made over the past 2 years. I will snap some and get them to ya.
#29
Notorious BIG
Originally Posted by krambo
Josh,
sweet! thanks bro!
#30
Just so you guuys know, the 2003 LB7 Duramax uses a MAFS with a 102 MM diameter.
The 2006 Duramax aircleaner uses the same sensor but its slid into a 123mm bore.
these MAFS can be used in any straight secotion of pipe, you just mkae a hole slide teh MAF into teh hole and fasten teh device securley.
These are much easier to plumb than the standard 99+ truck and LS6 85mm, LT1/LS1/L31 75mm MAFS.
peace
Hog
peace
Hog
