100MM MAF and 4" intake for Radix
Old 04-14-2007, 07:18 PM
  #21
Notorious BIG
Holty's Avatar
just remember, i'll also need to figure out a way to mount the 100mm maf to the airaid intake box. with all this custom work it might not be worth buying it. don't know?
Old 04-14-2007, 07:20 PM
  #22
what a rush!
moregrip's Avatar
let me know what you want to do bro, I have a stock MAF I might be willing to part with as well
Old 04-14-2007, 07:24 PM
  #23
Notorious BIG
Holty's Avatar
well, i know for sure i want the intake tube off of you. now i'm thinking maybe stay with the stock maf, not sure yet. what are you using grippy? errrr i mean going to use?
Old 04-14-2007, 07:25 PM
  #24
what a rush!
moregrip's Avatar
the 90mm TB, LPE 4" MAF, and custom intake setup
why would you still want the intake tube?
Old 04-15-2007, 05:32 PM
  #25
Moderately Differentiated
dewmanshu's Avatar
f-er is confusing isn't he? He doesn't even drink. seems he is going with the 4" (LINKY). I am curious of your intake setup as well grip. the maf to TB part.
Old 04-15-2007, 05:34 PM
  #26
what a rush!
moregrip's Avatar
nothing tricky, a 4" tube with two 4" couplers
Old 04-15-2007, 05:41 PM
  #27
Notorious BIG
Holty's Avatar
I want a stock setup to use until i can get this custom intake built and who knows if i'll even be able to figure it out. i don't understand how you get a straight piece of tube to bend in all the different directions you need to route it from the TB to the MAF, then to the air box???
Old 04-16-2007, 06:53 AM
  #28
krambo's Avatar
Josh,
I need to send you some pictures of my 3 custom intakes I made over the past 2 years. I will snap some and get them to ya.
Old 04-16-2007, 02:07 PM
  #29
Notorious BIG
Holty's Avatar
Originally Posted by krambo
Josh,
sweet! thanks bro!
Old 04-22-2007, 02:35 PM
  #30
hog
hog's Avatar
Just so you guuys know, the 2003 LB7 Duramax uses a MAFS with a 102 MM diameter.
The 2006 Duramax aircleaner uses the same sensor but its slid into a 123mm bore.
these MAFS can be used in any straight secotion of pipe, you just mkae a hole slide teh MAF into teh hole and fasten teh device securley.
These are much easier to plumb than the standard 99+ truck and LS6 85mm, LT1/LS1/L31 75mm MAFS.
peace
Hog
Quick Reply: 100MM MAF and 4" intake for Radix
