10lbs Boost plus 100 shot- what u think?
I've got a fresh lq4 with a side mount whipple set at about 10 psi, i already have methenol injection and a wide-ban and plan on getting it dyno tuned. Do u guys think the motor will last with a 75-100 shot of the good stuff, assuming the tune is good? By the way the bottom end is stock.
Spray a 50shot dry and compensate with adding fuel in the tune.. You wont get much out of it if u spray it with a wet kit unless its direct port..
And yes 42lbs seem a little low for the psi ur pushing. On the tvs1900s we need 60lbs for safety when only pushing 10-11lbs of boost.
