112 Radix + 408 + Turbo?
#21
I'm no physicist, but it would seem that any given blower would only be able to move/allow a certain maximum amount of air through it, based upon the rotor diameter, size, speed, etc. At a certain point, if your motor needs more than this maximum, the blower becomes an impediment.
For this to work with a 112 on a 408, I think you would need to be able to bypass the blower completely after a certain RPM.
Everyone who knows me knows I have wanted to do a compound boost setup for a long time. Was going to do it on my 4.8 when I had the STS and use a M90 supercharger, I just needed more $$
#23
Moderately Differentiated
I like the compound scenario, I have always thought it would work, but certainly with alot of experimenting, otherwise these manufacturers who have HUGE budgets for these experiments would have introduced it in mass form already. I think there is a a workable scenario, just not applicable in the masses.
#26
that's what i was imagining. I agree up front, room is valuable as you'll need liquid to air intercool for the blower, then A/A for the turbo, so room is certainly limited, but I bet...I bet the intercooling of the turbo will help battle some of your roots blower issues. But who cares if you pulley up, I am just curious how that works physically with a blower pullied to only GIVE 7 PSI but have a turbo in front of it giving 20psi.
yes yes yes I agree , it will be tight on room and the roots will still steal some IAT's from you, but I bet it would work in some sense.
#27
I would run a large A/A after the turbos before the radix. The efficiency of the radix shouldn't need to be stretched too much, so I wouldn't expect it to make more heat than normal. If I run 10psi out of the turbos through big enough intercoolers, how much heat above ambient would I end up with?
For example, if I ran 14.7psi into the radix, the adiabatic islands on the flow chart will remain the same at twice the flow rate, correct?
