112HH + LEP Forged 370= 636 awtq 3500 rpms
#21
If the graph doesn't start until 3500 rpm because there is a loose converter in the car, then a stock stall converter would take advantage of what looks like a lot more torque below 3500 rpm.
It seems like the torque might peak 1000 rpm earlier, extrapolating the graph in that area.
You might get a little more HP by raising the rpm, but you might need higher (lower numerically) gears to take advantage of that torque.
#23
Its all about Horsepower,does not matter how or where just as long as you have it (owned).
It would be great to drive it out say 600 miles cap a 11 sec run and drive it back.....
we should see.
the 20 k was for reliability.
Why not gm spends millions on that same concept.
we should see.
#24
