12.5 afr?
OK, I just had a reputable tuner set me up and he knows it's a FI motor. He said it would be fine. But I read different here, this being why I asked.
How do I confirm? What are trouble signs? Detonation?
Is there a spark plug check procedure?
In your opinion is 12.5 an absolute NO! NO!
Remember only 6.9 - 7 psi. 93 Octane.
I drove it in @ 10.5 and detonating. He pulled some timing and did the AFR and more I do not understand.
I have a PLX wide band.
The truck is running better than it ever has and in the 98-degree heat. Not a hint of detonation.
And then there is the great and much respected input I get from all of you guys here.
Not to forget the tuner whom is very well known for tuning boosted applications.
So here I am all tight in the gut about the differences of opinions and concern about my motor. Heh! If I go back to the tuner and tell him to make it richer it will not be pretty.
Is there any way I can monitor or check for danger? I do have a live diagnostics feature in a hand held.
Hunt&Fisherator
If your tuner has a problem tuning the vehicle how you want it then you should go somewhere else anyway IMO. It doesn't belong ti him, so in turn he should respect your wishes... What's the timing set to??
Like I said, I'm sure it flys, but with these weak *** stock pistons all it takes is the first drop of bad fuel or the slightest hint of knock due to increased load or heat then you'll be researching a new shortblock... Ask me how I know
