12 volt oil pump?
12 volt oil pump?
I have been looking for a oil pump for a remote mount turbo setup for two weeks now! I bought a surflow but it will not flow enough oil. I need something that will flow 3+ gallons per minute. I was looking at a groco oil pump that pumped 4 gallons per minute but the person I talked to said he wasnt sure if it would last to long pumping all the time. If I could figure out what STS was using I would buy it but they wont tell me Does anybody know what I should use or If anybody knew what kind of pump STS used that would work good to.
Thanks
Yellow
Thanks
Yellow
This pump was posted up some time ago. It does not flow as high as you need but maybe you can reduce the flow somehow. I am sure the turbo will not need anywhere near 3 GPM flow but I will leave that up to you.
Mocal Oil Cooler Pump
Originally Posted by kbracing96
Hey Yellow, something to think about, but if your letting your turbos consume 3-4 GPM, don't you think you might be taking to much oil away from the engine?
Originally Posted by MrXerox
Why would a tiny turbo need 3-4 GPM of oil flow?! I would put a restrictor in the feed line and use any of the above mentioned pumps and be done with it.
I think STS uses a Mocal oil pump. You can pick up cheaper parts similar to these if you search Petro-chemical supply stores online or locally. These stores also supply high pressure solenoids (ie. nitrous, CO2 etc.) as well as misc. relays and pressure switches. Here's the link for the Mocal pump.
www.racerpartswholesale.com/mocal1.htm
pupi305
09-14-2015 11:40 AM
Ferocity02
07-17-2015 07:05 PM
