145 amp alternator w/ Procharger on 5.3L?
Old 05-11-2006 | 10:05 AM
Superado's Avatar
11 Second Truck Club
Default 145 amp alternator w/ Procharger on 5.3L?
Hey guys, have any of you installed the 145 amp (p/n 10464476) on your ProCharged 5.3L?
There has been mentioned the need for a different belt, of course ours is different already, so I was wondering if any of you have done this upgrade and if so, what new belt are you using to allow for the difference in size?
Also, if there are any other issues to be concerned with, please speak up...
It's already so tight in that area...see thread about having no access to power steering fluid...
Thanks in advance.
Old 05-11-2006 | 10:11 AM
Nick™'s Avatar
I don't know the belt size or the actual difference, but I swapped alternators on my otherwise stock pulley system.... my suggestion is to take the part number for the trucks with the 105 amp and the 145 amp and find the difference in legnth (about 1/2"), then take your current procharger belt and add that to it's size and you should be fine.
Old 05-11-2006 | 10:22 AM
SCIV's Avatar
Yup. That's my setup.
Old 05-12-2006 | 09:34 AM
Superado's Avatar
Do you happen to have the belt part #?
Or the size needed?
Old 05-13-2006 | 06:55 AM
black_yukon's Avatar
Don't know if this helps at all but my truck has a 130 amp and I needed a 112" belt. Gatorback part #4061120
Old 05-13-2006 | 11:40 AM
Bad_Apple's Avatar
I think thats right...
madmann26
04-29-2020 10:17 AM
drummer0415
11
10-24-2015 09:16 PM
CD82
10-23-2015 08:32 AM
old motorhead
09-29-2015 09:22 PM
murderedSS
09-27-2015 11:16 PM
