2300 too big for 5.3?
Old 09-19-2012, 12:37 PM
03sierraslt's Avatar
Is a 2300 too big for a 5.3? Ya, Kinda. Would it work, yes. Unless you plan on going big and or adding more CI then its not needed. Hell TimZ is pushing 14psi on a Cammed 6.0 with his 1900. (Overdriven, 8rib)
Old 09-19-2012, 12:53 PM
lol I want to slap one of those new whipple 4.5L blowers on my stock LS3 2010 camaro. I dont really understand how it would hurt. Lower IAT's and lots of room to grow. Or am I wrong? I know more about turbos than PD blowers
Old 09-19-2012, 01:03 PM
If you spin them to slow then they are out of their efficiency range also just like a turbo. It will still work however. If the blower is way to big then you are just adding drag for no reason, now the motor has to spin that much more wieght.
Old 09-19-2012, 01:05 PM
skoal bandit's Avatar
I guess I will stick to a 1900 if I decide to do it. And yes I have rode in a turbo, it was pretty SICK! I just always like the blower look.
Old 09-19-2012, 01:08 PM
Import Moderator
beastmode's Avatar
I was kicking around a 2300 on a 4.8 but after talking to Pat I think the 1900 would be plenty for what I want. Might still end up turbo tho lol.
Old 09-19-2012, 01:10 PM
Import Moderator
beastmode's Avatar
Kinda hard to beat the install of a pd too.
Old 09-19-2012, 01:25 PM
Thanks for clearing that up. Makes sense. How many cubes would be needed to require that 4.5L blower? I mean The copo camaro runs a 4.0L whipple on a 327 CI and they run 8's out the box
Old 09-19-2012, 01:36 PM
With the COPO Camaro you gotta consider the flow #'s that motor makes, the RPM it spins and the boost level as well. Kinda like apples to Oranges if comparing to a stock motor.
Old 09-19-2012, 01:53 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Originally Posted by skoal bandit
I been kicking around the idea of getting into FI. I have a cammed and full bolt on 5.3 with 3000 stall in a CC 2008 5.3L. Is the 2300 too much overkill for the 5.3 or should I stick to a 1900?
Back to the original question.
No, a 2300 is not too big for a 5.3 liter. That is a myth. Here's some proof. https://www.performancetrucks.net/fo...rmance-505827/
Old 09-19-2012, 02:08 PM
Import Moderator
beastmode's Avatar
2300 on a 4.8... I believe he is a member on here
EDIT: Here he is
https://www.performancetrucks.net/fo...-today-491743/
Quick Reply: 2300 too big for 5.3?
