255 vs bosch 044
Old 10-06-2009, 08:05 PM
  #21
nonnieselman's Avatar
Originally Posted by Whippled 496
Extend the relay run time at key-on? Is that possible? I dont think there is a place to do that in the software.
I see all mine are set pretty much to 0 but look at B3201
Old 10-06-2009, 08:24 PM
  #22
Ender06's Avatar
I know alot of diesel guys using this, anyone used one of these??
http://www.jegs.com/i/Edelbrock/350/1792/10002/-1#
Old 11-03-2009, 07:16 PM
  #23
Ender,, thats a low pressure pump. 12psi.
Old 11-03-2009, 07:24 PM
  #24
Black'Rado's Avatar
Anyone have issues with pressure dropping before you crank? The 044 doesnt come with a check valve so unless you added one to the pump before you installed it the pressure is gonna drop at key-on if you dont crank immediately. Its not a big deal, just wondering if anyone added the check valve when they did the install. Here is the second page of my install with pics. It shows the check valve from summitt i plan on eventually getting.
https://www.performancetrucks.net/fo...=431146&page=2
my walbro 255 is like that... i just turn key 2 times and starts right up....id like to see if it could be tuned to prime more.
Old 11-04-2009, 09:34 PM
  #25
1BADAZZSS's Avatar
Just run dual 255 intank pumps and be done
Old 11-04-2009, 10:08 PM
  #26
MikeGyver's Avatar
I'm considering adding a delay-on-break relay into the pump relay coil circuit.
Old 05-01-2010, 12:51 PM
  #27
TOTM: January 2007
Last Call's Avatar
Stock48 - What pump did you end up going with?
Vortec350ss
10-10-2015 09:11 PM
sTNT971
09-26-2015 04:22 PM
sTNT971
09-11-2015 02:38 AM
chevstang421
09-10-2015 09:16 AM
lxcoupe
09-02-2015 12:58 AM
Quick Reply: 255 vs bosch 044
