3.3L on a vette
Old 08-15-2007 | 11:29 AM
BlownChevy's Avatar
blownerator
Originally Posted by Crash Dummy
He has serious problems with that tiny air cleaner , it may make some huge torque but that blower is going to be strangled on the top end. I guess this falls under the bigger is better theory.
Old 08-15-2007 | 10:23 PM
fullthrottledan's Avatar
whats the hood look like? normal cowl hood?
Old 08-19-2007 | 04:49 PM
moregrip's Avatar
what a rush!
http://home.comcast.net/~badassc5/RJW.wmv
Old 08-19-2007 | 08:51 PM
moregrip's Avatar
what a rush!
another vid
http://home.att.net/~my03z/IDLE-REV.wmv
Old 08-19-2007 | 10:17 PM
2004SSS's Avatar
thats what i was thinking and not only that belt slip with the little *** 6 rib has got to be a problem.
Old 08-21-2007 | 10:32 AM
Blown2300's Avatar
There are so many things not right about that setup....
If your not making 1000+hp with a huge 3.3L supercharger.. you better go rethink alot of things..
Old 08-21-2007 | 10:52 AM
BlownChevy's Avatar
blownerator
LOL, good point
Old 08-21-2007 | 08:21 PM
Crash Dummy's Avatar
Former Moderator :(
Originally Posted by moregrip
What a complete fricking idiot , what does that video show other then he knows how to hack and beat the crap out of what at one time was a probably a good car. Revving a engine like that with a belt drive FI unit is so bad on it it isn't even funny. BAD! BAD! BAD! I would like to know were all these new out of the wood works FI specialist are coming from did you see the Trailblazer SS with the Procharger that had the cooler mounted to the lower radiator support, Absolutely 0 airflow may have well just used a piece of strait pipe. And the funny thing is they are trying to fool you and sell these products and of course all you can say is ( moral of the story is don't believe everything you see or read) 99% of these dyno queens never post numbers or 1/4 mile times and support YA!
Old 08-22-2007 | 02:38 AM
GMCHammer's Avatar
11 Second Club
6.5 psi 543rwhp/532t @ 9.4 afr!!!
2003 Z06 Ls6 stock bottom end, afr 205's (out of the box), LG G5X1 cam, Kooks 1 3/4 and Borla 2 tip stingers. WITh CATS and all smog equipment hooked up and functioning.
4 to 6 PSI sc pulley (shows 6.5 psi on dyno and 7.5 on road)
12 degrees total timing
97F ambient (Probably well over 100F in shop no ac, 2 floor fans blowing at car)
AFR's on MY wideband were in the LOW to MID 9's. The dyno sheets show a point leaner, which is normal when checking before and after cats.
Please remember, these are INITIAL results and you can see how things are moving as I lean it out a bit at a time.
Also, this is on a Dynomite dyno, not a dynojet
Nice numbers for a stock bottom LS6!!!
Old 08-22-2007 | 11:08 AM
BlownChevy's Avatar
blownerator
If you believe everything you read
Quick Reply: 3.3L on a vette
