317's on a 5.3???
Old 04-11-2008, 04:36 PM
iMpoSStoR's Avatar
Default 317's on a 5.3???
Has anyone used 317's on a 5.3 for a forced induction application? If so, what type of gasket did you use?... Also how did the set up work out? Please input any information ya'll have. Thanx.
Old 04-13-2008, 11:23 AM
lt1s10's Avatar
I too would like to know...
Old 04-13-2008, 11:42 AM
FormerVendor
Richard@WCCH's Avatar
This has been done by a number of people. You'll need to use the 6.0l head gaskets. The 317's will take your compression ratio down by well over a full point. The larger valve sizes and improved ports will help the top end power. Be careful how much boost you run as head gakset sealing is compromised by the chambers overhanging the cylinder bores.
Hope this helps.
Richard
Old 04-13-2008, 12:17 PM
Formerly Low_LQ4 - 6/6/10
Low_LSX's Avatar
How about 5.3 heads on a 6.0 what would that lead up to?
Old 04-13-2008, 12:44 PM
InchUp's Avatar
Bad valve shrouding issues with poor flow characteristics on top of rather high compression ratios. If possible, try to bolt on heads that are designed for the bore intended.
Old 04-13-2008, 02:49 PM
TG02Z71's Avatar
Hope this helps.
Richard
What kind of comprimise does a 5.3l bored to a 5.7l have is any concerning the sealing area and boost psi??
Old 04-13-2008, 03:23 PM
TURBHOE's Avatar
wouldn't it unshroud the valve? the bore is bigger in the 6.0 than the 5.3. the ls1 guys do this all the time to raise compression.
Old 04-13-2008, 03:56 PM
Low_LSX's Avatar
Originally Posted by 4.8T
wouldn't unshroud the valve? the bore is bigger in the 6.0 than the 5.3. the ls1 guys do this all the time to raise compression.
So it would work. The only thing that would change is the compression? anymore details.
Old 04-13-2008, 04:03 PM
9 Second Truck Club
stock48's Avatar
Stock 6.0L heads flow alot better than stock 5.3 heads. So unless the 5.3 heads are ported with larger valves you might be wasting your time. I would go with the LS6 head, or ported LS1 heads if you are going through the trouble. Swaping heads on these truck's is a lot of work, if you do the job right.
Old 04-13-2008, 05:57 PM
ForcedTQ's Avatar
317 cylinder heads are designed for a 4.00" bore with larger valves that will be closer to the stock 5.3L cylinder bore, thus shrouding the valves. 5.3L cylinder heads on a 6.0L bore will allow larger than stock valves and opening up the combustion chamber without shrouding the valves against the cylinder wall.
Quick Reply: 317's on a 5.3???
