370 boost motor, compression questions
Old 06-29-2013 | 10:49 AM
Razor's Avatar
BMF
Best bet, call an engine builder who sells/builds forced induction motors and ask their opinion. Then buy a part or two from them for their time!
Old 06-29-2013 | 11:21 AM
1994Vmax's Avatar
My plans keep changing so my signature may not be accurate. The engine I am building has -14 cc diamonds with 243's netting me roughly stock LQ4 compression with the LS9 gasket. The goal of the engine is upwards of 1000 hp...... That said I may use my KB kit I have on the stock LQ4 in the 2500 and use this built 370 in something lighter..... like a half ton I have a line on for when I get home. If machine shops didn't take so bloody long to do anything I wouldn't change my mind so many times, lol.
Old 06-29-2013 | 01:36 PM
Gadgetized's Avatar
Originally Posted by LsF-150
Correct me if I'm wrong but didn't the cast headed lq's have a different length crankshaft, requiring different flexplate/flywheel and/or TC...might be something to check into before he commits any money to the project.
The cranks are about .400 longer. You can not run a good SFI approved flexplate (from what I have heard) with a stock converter. The flexplate is thicker, and you will not have the room. If you run that crank and upgrade to the good flexplate, just tell your converter manufacturer, and they will get you the right converter.
black6spdz
07-16-2015 01:32 AM
121
07-16-2015 12:18 AM
grantpo
07-15-2015 12:21 PM
ALynch
07-06-2015 09:49 AM
Quick Reply: 370 boost motor, compression questions
